Phone Help!! Samsung Infuse 4G
This is a discussion on Phone Help!! Samsung Infuse 4G within the Samsung Infuse 4G forums, part of the Samsung Android Phones category; Hi, I got the Samsung Infuse 4G phone. I wanted to know what is the best way to have longest battery life and what is ...
Thread: Phone Help!! Samsung Infuse 4G
    Junior Member lanuk33's Avatar
    Hi, I got the Samsung Infuse 4G phone. I wanted to know what is the best way to have longest battery life and what is the best way to save your Data. In the Iphone you can turn on E (Cellular Data) and not 3G, to save data, though much slower. Can you do that on this phone? Also, when I go to create a text message, all the contacts like from gmail or whatever come up, I don't want that, how can i just have my contact list from the phone numbers in my phone.
    Moderator AndroidIsTheTruth_attdroids's Avatar
    Hook Em Texas
    Screen brightness plays a big role in battery consumption. You can turn on and off features like work gps bluetooth from the notification bar. Also turning on and off sync auto and background service can increase your battery. There's also apps that can help but I don't use them. As for 3g/2g Samsung left that option off but there's apps you download to set up a widget for those options. I use power widget. As for the contact numbers go into your contacts and hit the menu button for options. Select more and select display. From there you can pull open all linked contacts and check what you want displayed.
    thank you, i am also having this issue where when my DATA is OFF an dsomeone sends me like a picture, it says downloading...when i turn my DATA on to download it nothing happens
    Banned lijie's Avatar
    I use power widget. As for the contact numbers go into your contacts and hit the menu button for options. Select more and select display. From there you can pull open all linked contacts and check what you want displayed. windows tablet pc
    Android Lurker whistler7's Avatar
    Dec 2011
    North Carolina
    2 times
    Also disenabling your Wi-Fi settings until you need them and use background sync sparingly instead of having it run in the background constantly.
    Junior Member Ed Ely's Avatar
    Jun 2011
    KY
    I am still staying with Samsung. My Captivate drove me nuts.
    My first, purchased on Black Friday in Nov. last year lasted three
    weeks before I had to replace it in December 2010. From then until
    last night, it was a nightmare.
    Customer Care with AT@T agreed to totally replace it with the Samsung
    infuse, no charge or cost to me. Of course I had to sign up for a new two
    year commitment. However, I have 30 days to give it a try. If I no like,
    then back it goes to AT@T. It does have a 1 year warranty also.
    I sure hope the Infuse works for me!!
    WERA689
    Guest WERA689's Avatar
    So do we, Ed! Welcome to our forums...I hope we can help you with your Infuse should you need it.
how do i turn on 4g on my infuse
how do i turn on 4g on my samsung infuse
how to activate 4g on samsung infuse
how to enable 3g on samsung infuse
how to turn on 3g on samsung infuse
how to turn on 4g on samsung infuse
my samsung infuse keeps turning off
my samsung infuse keeps turning off and on
my samsung infuse keeps turning on and off
samsung infuse keeps shutting off
turn on4g samsung infuse
why does my samsung infuse keep turning off
