Get a second battery
This is a discussion on Get a second battery within the Samsung Intercept Accessories forums, part of the Samsung Intercept category; I am tired of my cell phone always dieing. Any others having issues with their battery life? I recently bought a second battery from amazon ...
Thread: Get a second battery
    Junior Member Asclepius's Avatar
    [ame="http://www.amazon.com/Capacity-Lithium-Ion-Battery-EB504465VA-Intercept/dp/B0041NJQB6/ref=sr_1_8?ie=UTF8&s=electronics&qid=1284217291&sr =8-8"]Amazon.com: High Capacity Lithium-Ion Battery (EB504465VA) for Samsung Intercept M910 / R880: Electronics[/ame]
    I like having a spare battery available so I can just switch when needed.
    I would recommend to pick up a clip charger also so you can charge the battery outside the phone.
    The battery I received was awsome and would consider to get a 3rd.
    Super Moderator jak89's Avatar
    Asclepius i did the same thing when i got my phone. What alot of us here have been trying out is an app called Juice Defender and it does wonders for battery life. Check it out i think its the answer you've been looking for.
    Junior Member michaelbenavidez's Avatar
    How can I enable the JAVA on my EVO 4G
how to enable javascript on htc evo
samsung intercept accessories amazon
samsung intercept hi-capacity battery
second battery cell phone
