PC Doesn't Recognize Transform
This is a discussion on PC Doesn't Recognize Transform within the Samsung Transform Tech forums, part of the Samsung Transform category; FWIW, I run Win 7-64bit and have not ran into any issues. Just a thought...if the cordless devices are locking up do you have a ...
Results 11 to 20 of 33
Thread: PC Doesn't Recognize Transform
    Junior Member rmdooley1's Avatar
    PC - USB - Transform
    Just a thought...if the cordless devices are locking up do you have a standard USB mouse/keyboard that you can try just to see if the same thing happens?
    Regarding unreliable copy to-from the removable media perhaps you could try a different memory card...or maybe reformat the existing card?
    $.02
    Junior Member readermo's Avatar
    Thanks for the replies. Glad to know that I wasn't the only one.
    Shortly after posting, I went ahead and swapped my transform for an epic and, holy moley, what a great idea that was. It's more expensive (and I'm paying $10 /month more for 4g service (which isn't even available in my town)) but it's a MUCH better device.
    It hooks up to my XP computer without a hitch. Interestly enough, though, the windows 7 machine still doesn't like it. Tha's ok. That computer is the wife's, and I have been banned from using it :-D
    The transform was a good phone, but if you are more than a casual user (and you're still within your 30 day window (and you have an extra $10 to blow)) i'd highly recommend the epic or the evo (I went with epic because I can't live without the keyboard.))
    Junior Member QuantumRift's Avatar
    Quote Originally Posted by readermo View Post
    I got it working. It was painful, convoluted process and involved Quicktime, iTunes, and that damned "Bonjour" service being ganked up, uninstallable and not installable. I had to literally ginsu the registry to remove those and any bits and traces of apple apps (updater, etc). After that, I got a good reinstall of said apps, but it hosed my winsock and path statements. Once I cleaned that crap up and, even the Transform now works great when I USB it to m PC. GO figure.
    WE do not have 4G speeds here, mostly 2G and 3G, so I am quite content with the Transform and it's abilities. We paid $69 for the phones and that's quite enough, and don't have to cough up $10 extra month per phone for service we may not see down here for a while yet. And I certainly won't pay $300 for a phone, even it it scratched my back and made breakfast!
    Junior Member lin22's Avatar
    Wink USB not being recognized
    OK, so after days of trying to get my computer to recognize my transform and after downloading the current drives from Samsung for my transform I finally called their support line. Luckily my daughter also has a transform because I grabbed her usb and tried it and it immediately connected. The support person said that I may have gotten a usb cable that charges only and my daughter got the data usb which charges AND transfers data. Once I used my daughter's cable I was able to sync my phone and get all of my music files. Here is the number on my "charge only" usb cable: RT1Z818OSE (or close to that-damn writing is so small! LOL) the "data" usb cable is: DW1Z917WSE (I think!). Needless to say you should have an idea after checking your usb cable as to which one you have and if it's the charger only cable you now know why it won't recognize your connection for data sync. The support tech recommended that you ask sprint to replace it first, if they won't give them a call and they will see what they can do.
    Hope this gives you some answers.
    Quote Originally Posted by lin22 View Post
    Yes, that absolutely makes sense - I made sure that I had and use the cable that came with the phone for charging and USB data transfer. I have the cable labled just in case now. But my issue was that I had other PC issues, most noteably with Quicktime, Bonjour, and iTunes. However, this is great info to have. Thanks!
    Junior Member Trainwreck's Avatar
    Holy usb sync! It freaking worked!
    Just when I was about to post another reply voicing my complaints about the terrible QA/QC of :sprint: and Samsung with respect to the Transform, I was able to get it to connect!!!! And this is after days of plugging and unplugging different cables; installing, uninstalling, and reinstalling drivers from Sprint and Samsung; registry editing; and various chants, prayers, and incantations intended to exercise whatever demons have been inhabiting my phone that prevent it from connecting via USB.
    What I think finally did it was this:
    I went into the SD card menu in Settings (on the phone) and unmounted the card.
    Then I connected the cable and BAM! I got the icon at the top of the phone's screen saying USB was connected. Windows still was stubbornly refusing to recognize the device, but at least this was progress.
    So, I plugged in the cable and unplugged it a couple of times and tried mounting the card to the Windows system via the phones SD card menu. I think the last thing I did was mercilessly unplug the cable while the card was "mounted" to the USB cable (still not recognized by windows). Finally, I rebooted the phone (while plugged into USB cable) and sat it next to my computer.
    As I was browsing the posts in this forum, I decided I'd voice my opinion and noticed that the cable had fallen out of the phone. When I plugged it in - SHAZAM! Windows recognized the USB modem, the USB storage device, and the Android device!!! WOW! :eek:
    Sorry I can't be more specific about exactly what I did, but whatever it was, it seems to be working now .
    I'm going to chuck this phone as far as it will fly.
    Okay, I get it. Very funny.
    After I posted that last message I went to see what could be done with a newly connected Transform. I noticed the phone was complaining about USB debugging mode being on, so I went into the Applications - Development menu and turned debugging mode off.
    Everything went to hell. Windows refuses to recognize the phone once again and nothing connects. Stupid phone. I'm starting to HATE sprint and their horrible QA/QC with Samsung devices. The last two Samsung phones I have owned with sprint (Instinct, Rant) have been full of bugs and annoyances. The Rant was better than the Instinct, and the Transform has taken frustration to a whole new level of ridiculous. Thanks for the inflamed ulcer, Sprint.
    Cool
    Quote Originally Posted by Trainwreck View Post
    I feel your pain...after I got mine working I just let it connect and didn't mess with SD card or debugging...and mine is still working (so far)...
    Junior Member Jake876's Avatar
    All you have to do is go to your notifications when you plug it in and hold on the USB tab and then pick the option to connect.
    Junior Member ronnbrown1993's Avatar
    i got it to work what i did was turned the ph off plugged in usb cable to computer and ph then turned ph back on and as the phone was rebooting my computer reconized the sd card and mass storage now i can transfer files back and forth hope this helps
  1. Allshare won't recognize any devices
    By rm1978 in forum Samsung Galaxy S2
    Last Post: 12-28-2011, 08:29 AM
  2. SD card won't recognize
    By dinkygreg in forum HTC Hero
    Last Post: 02-24-2011, 05:34 AM
  3. Main music player doesn't recognize music.
    By phyllis in forum LG Ally Help
    Last Post: 11-21-2010, 09:23 AM
  4. Root question, something uninstalled I don't recognize
    By blackmetalbuick in forum LG Ally Hacking / Development
    Last Post: 11-01-2010, 06:13 AM
  5. Computer will not recognize Ally
    By lero1324 in forum LG Ally Help
    Last Post: 10-03-2010, 05:32 PM
connect samsung transform to pc
how to connect samsung transform to pc
samsung sph-m920 drivers
samsung transform driver windows 7
samsung transform not recognized by computer
samsung transform ultra driver
samsung transform ultra driver download
samsung transform ultra drivers
samsung transform ultra drivers windows 7
samsung transform ultra not connecting to pc
samsung transform ultra usb driver download
samsung transform usb device not recognized
trouble connecting droid transform to computer
usb driver samsung transform ultra
usb drivers for samsung transform ultra
