texting issues
This is a discussion on texting issues within the Samsung Transform Tech forums, part of the Samsung Transform category; I keep trying to text on my keyboard and as soon as I hit a key ANY key it sends me to gmail... the calander.... ...
Thread: texting issues
    Junior Member carrie521's Avatar
    texting issues
    I keep trying to text on my keyboard and as soon as I hit a key ANY key it sends me to gmail... the calander.... the gallary.... just to random places. I was using the screen to text and now that won't even work it just pops up a little bubble that says "text input". Any ideas on what to do? I took it into the store and they updated it and did what they said they could but I still can't text...
    Junior Member niteman's Avatar
    Your keyboard shortcuts are enables and sound like they're out of whack. click on the link to this thread http://www.sprintdroids.com/forum/sa...-me-email.html
    Junior Member short2916's Avatar
    Disable Keyboard Shortcuts Keys (Quick Launch)
    To Disable the Quick Launch feature:
    1. Settings>Applications>Quick Launch
    2. Press and hold each letter that has a Quick Launch Application associated with it and select "Clear"
    Same thing happened to me and this worked...
android for texting issues
disable keyboard shortcuts samsung epic
epic 4g keyboard issues
epic shortcut keys
how do i turn off shortcuts on my key board for android
how to turn off keyboard shortcuts on samsung epic
how to turn off keyboard shortcuts samsung epic
samsung epic hotkeys
samsung epic keyboard issues
samsung epic keyboard problems
samsung epic keyboard shortcuts
samsung epic shortcut keys
samsung stratosphere texting problems
turn off keyboard shortcuts epic 4g
