bluetooth won't connect; error invalid pin or passcode
This is a discussion on bluetooth won't connect; error invalid pin or passcode within the Samsung Transform Tech forums, part of the Samsung Transform category; I have Samsung Transform and I am trying to pair and connect to a Jabra Cruiser 2 in-car speakerphone. The phone recognizes Jabra Cruiser2 but ...
Thread: bluetooth won't connect; error invalid pin or passcode
    Junior Member jlhughes's Avatar
    Unhappy bluetooth won't connect; error invalid pin or passcode
    The phone recognizes Jabra Cruiser2 but when I select "Pair and Connect" I get the following error message:
    "There was a problem pairing with JABRA CRUISER2 because the PIN or Passkey is incorrect."
    I was NEVER asked for the PIN or a Passkey.
    Any ideas on how to get the Jabra Cruiser2 to connect
    Junior Member Trainwreck's Avatar
    I am having the exact same problem. I was able to get it to pair and connect one time. I was also able to sync my contacts between the Cruiser2 and the Transform, but when I pressed the "FM" button on the Jabra, it went belly up.
    Now I can't even get the Transform to recognize that the Cruiser2 is in pairing mode. It's like the Cruiser2 is nowhere to be found, as far as the Transform is concerned. I don't even get the error message the previous post describes, but I suspect that it has something to do with an invalid PIN code.
    I tried another phone, and it was able to connect to the Cruiser2 without any problem at all, so its pretty clear that the issue is with the Transform.
    I have tried resetting the paired devices list in the Cruiser2 and have deleted everything in my bluetooth devices list on the Transform, but nothing works. It might as well be a couple of bricks trying to connect. I had a call into sprint customer service, but I got disconnected and I just don't have time to sit on the phone waiting all day for somebody to help me.
    Anybody else know what's going on???
    smh
    smh is offline
    Android Lurker smh's Avatar
    Mar 2013
    JABRA Cruiser
    TRy to use this website.. I liked very much Bluetooth Pairing Guide | Jabra
    Quote Originally Posted by Trainwreck View Post
  1. Home screen apps
    Last Post: 01-07-2011, 08:39 PM
  2. how do I get new homescreens?
    Last Post: 09-15-2010, 01:04 AM
bluetooth unable to communicate with fitbit incorrect passkey
could not pair because of incorrect pin
couldn't pair invalid pin or passkey
couldn't pair with u8 because of an incorrect pin or passkey
couldnt pair with one because of an inorrect pin or passkey
fitbit charge hr couldnt pair with android phone because of incorrect pin or passkey
impossible to pair jabra classic v0.5.0
incorrect pin or passkey on chromecast
jabra coach won't connect incorrect pin
jabra talk incorrect pin
lge dtv bcm20702a1 passkey
misfit shine says incorrect passkey
pin passcode shows up but will not pair to bluetooth on car pin passcode
why wont my jabra connect due to pin code
xiaomi-redmi-note-4-dual-sim-64gb-4g-lte? invaild pin or passkey
