I find the battery that came with my Transform to be totally inadequate. It does not last 8 hours, regardless if I am using the phone or not, and don't tell me that I have too many applications running. Applications is the reason I got a smart phone. If the battery cannot support the applications, then it shouldn't be a smartphone.
Does anyone know if there is an extended battery being made available for the Transform?
