Roaming Charge for NOT Answering
This is a discussion on Roaming Charge for NOT Answering within the T-Mobile forums, part of the Android Phone Carriers category; Recently I was in Montreal, Canada, and when there I didn't answer my phone. When I saw my bill I discovered I was charged each ...
Thread: Roaming Charge for NOT Answering
    Junior Member kentborg's Avatar
    Recently I was in Montreal, Canada, and when there I didn't answer my phone. When I saw my bill I discovered I was charged each time I didn't answer. A roaming and a long distance charge.
    I guess they were charging me to forward to Google Voice.
    Did this happen because I dragged the "don't answer" thingie? Could I have waited it until it turned into a "no answer" and avoided the charges? Clearly if I turned off my phone's radio I wouldn't get charged, but do I have to do this before I cross the border? Could I avoid the charge by switching to T-Mobile's voice mail before I leave?
    Thanks,
    -kb
    Member DaveC's Avatar
    Sounds similar to what we have in Europe. If you cancel an incoming call then you get charged for the divert to voicemail even if the caller does not leave a message.
    I advise people to turn off the forwarding before leaving their home country
    Who Charges?
    But who charges? I can see that if my home carrier charges for the forward that it would still charge when I am roaming, but how does the roaming carrier get in on the act for my not answering a call?
    Does it matter whether I refuse the call or just let it ring?
    -kb
    It's got to be because of forwarding because that's typically considered air time. A call sent your carrier's voicemail should not incur charges regardless if it gets sent there by you pressing "don't answer" or waiting for the ringer to time out. However, it doesn't surprise me that forwarding to another service costs...
    Junior Member mocchiatta's Avatar
    Woah! I guess it's a good thing I read this before preparing for a trip over to Europe! Prepping for barista lessons and wanted to have my phone ready for the 3-day convention.
    Senior Member rioja's Avatar
    Here's my experience with this on Rogers in Canada. I travel to the US frequently and all unanswered calls are forwarded to my work VM system (I don't use the carrier's VM at all). Also, this is without call forwarding on my plan.
    If I'm NOT roaming and don't answer a call and it forwards to my work VM, I'm charged at flat rate ($0.10 per minute) for the forward.
    If I'm roaming and don't answer a call and it forwards to my work VM, I'm charged a flat rate ($0.10 per minute) + long distance call rates for the duration of the call!
    :mad: A rip-off to say the least!!
could get charge if roaming on there phone
do you get charged roaming if you dont answer the phone?
how does call forwarding avoid roaming charges
if i forward a call on android phone do.i.get charged
if im roaming and not using my phone will i get charged
if my phone rings on roaming am i charged
im roaming, my phone rings but i dont answer
receive long distance call galaxy s4 roaming charges
rodgers roaming charges if i don,t answer the call
tmobile don't answer roaming
when i get charge roaming fees if i dont answer my phone
when roaming and i receive a call but don't answer will i be charge
will i get charged roaming fees even if i do not use my phone
will i get charged roaming if i dont answer my phone
will the be roaming charges even if i do not use my phone
