Recent problems with T-Zones
This is a discussion on Recent problems with T-Zones within the T-Mobile forums, part of the Android Phone Carriers category; Hi All, I have unsubsidized nexus one. And starting today morning I started getting "subscription required" message. I removed the battery, restarted couple of times, ...
Results 21 to 30 of 33
Thread: Recent problems with T-Zones
  1. #21
    Junior Member OffbeatPhoto's Avatar
    same issue
    Hi All,
    I have unsubsidized nexus one. And starting today morning I started getting "subscription required" message. I removed the battery, restarted couple of times, but didn't work. I will wait for 1 more day and will update you all. I will also check with my friend at t-mobile if they have any sort of outage.
    But what i think is, t-mobile did a IMEI sweep or google provided them the list of IMEI numbers. Now t-mo knows who has t-zone and N1 and they stopped subscription. Hope this is not ture.
    mav
  2. #22
    Member Kit Fox's Avatar
    Quote Originally Posted by OffbeatPhoto View Post
    Hi All,
    mav
    I suspect you're not far off.
  3. #23
    Junior Member techietx's Avatar
    changed APN works
    I changed to the wap.voicestream.com APN and hopped right back on the band wagon - 2.8mbps down and 1.7mbps up. I had been using the epc.xxxxx.xxx APN. I hope this helps us out.
    techietx
  4. #24
    Quote Originally Posted by techietx View Post
    techietx
    Nope, didn't work for me. Tried that one and the other APN's arleady.
  5. #25
    Junior Member keyaaron's Avatar
    I tried all of the APNs earlier today and nothing would work.
    However, just now I tried wap.voicestream.com and I'm back up and running!
  6. #26
    HOLY CRAP!!! It's up again, working of the wap.voicestream one :D
  7. #27
    Member mush03's Avatar
    wap.voicestream.com works for me too YAY
  8. #28
    I had that on before though but it didn't work earlier; now it does. For now...
  9. #29
    Member raccord's Avatar
    today toggling didn't work, but a reboot did. weird... looks like ill try changing the apn if it stops working again.
  10. #30
    Junior Member ece3040's Avatar
    It's working now. I'm using epc.tmobile.com. I have download speed of 1Mbps just now. It was probably just an service outage...
android running t-zones
my t,zone is not working
recent problems with tmobile tampa
t zones not working
t-mobile recent problems
t-zones not working
tmobile tzones not working in tampa
tmobile tzones problem 2014
tzones not working on nexus 4
tzones problem 2014
