Am not able to send pictures using T-zone. Please HELP!!
This is a discussion on Am not able to send pictures using T-zone. Please HELP!! within the T-Mobile forums, part of the Android Phone Carriers category; Originally Posted by wannagotopopeyes I have the OLD 5.99 T-Zones plan and use just the bottom APN of this post with epc.tmobile.com. I get full ...
Results 11 to 13 of 13
Thread: Am not able to send pictures using T-zone. Please HELP!!
    Quote Originally Posted by wannagotopopeyes View Post
    I have the OLD 5.99 T-Zones plan and use just the bottom APN of this post with epc.tmobile.com. I get full 3G and MMS all the time w/o any trouble. Try setting your APN settings to default then rebooting then using only the bottom APN.
    Quote Originally Posted by baseballfanz View Post
    You need to create TWO set of APN
    1. For data
    Name: whatever you want to call it (I use Tmobile US)
    APN: internet2.voicestream.com
    MCC: 310
    MNC: 260
    APN type: default,supl
    Everthing else is either blank or not set.
    2. For MMS
    Name: whatever you want to call it (I use MMS)
    APN: epc.tmobile.com
    MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    MCC: 310
    MNC: 260
    APN type: mms
    Everything else is either blank or not set
    I have the Web2Go plan ($9.99/month).
    Yes the $5.99 t-zone use epc.tmobile,com for both data and mms so you can have one APN.
    Those on the $9.99 use internet2.voicestream.com for data and epc.tmobile.com for mms hence two APN.:D
    Ne:nexusx:uS One ROOTED
    Cyanogen Mod Nightly ROM
    Member wannagotopopeyes's Avatar
    1. For data
    MCC: 310
    MNC: 260
    2. For MMS
    MCC: 310
    MNC: 260
    APN type: mms
    Oh got it. Thanks for clearing that up.
    Android Lurker xRayx's Avatar
    1. For data
    MCC: 310
    MNC: 260
    2. For MMS
    MCC: 310
    MNC: 260
    APN type: mms
    Thank you so much this worked Great!!
