Am not able to send pictures using T-zone. Please HELP!!
This is a discussion on Am not able to send pictures using T-zone. Please HELP!! within the T-Mobile forums, part of the Android Phone Carriers category; Am not able to send pictures. Am currently using the T-Zone plan for data. Is anybody else having this issue? Here are my APNs: First ...
Results 1 to 10 of 13
Thread: Am not able to send pictures using T-zone. Please HELP!!
    Android Lurker xRayx's Avatar
    Here are my APNs:
    First APN
    T-Mobile US
    APN:
    Internet2voicestream.com
    APN Type:
    Default
    Second APN
    T-Mobile US-MMS
    epc.tmobile.com
    mms
    Thank you in advance.
    try these settings
    APN: epc.t-mobile.com
    MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    MCC: 310
    MNC: 260
    APN type: default,supl,mms
    Thank You for responding.
    Quote Originally Posted by baseballfanz View Post
    try these settings
    MCC: 310
    MNC: 260
    Do you have more then one APN set up? If so can you please post both of them.
    Thank You!!:nexusx:
    Here is mine. I only have one APN. Everything works well with these settings.
    APN: epc.tmobile.com
    Proxy: Not set
    Port: Not Set
    Username: none
    Password: ****
    Server: *
    MMS proxy: Not set
    MMS port: Not set
    MCC: 310
    MNC: 260
    Authentication type: Not set
    APN type: Not set
    Quote Originally Posted by bobbyphoenix View Post
    Proxy: Not set
    Port: Not Set
    Username: none
    Password: ****
    Server: *
    MMS proxy: Not set
    MMS port: Not set
    MCC: 310
    MNC: 260
    APN type: Not set
    It's not working out for me. did you input a password? or is it no set?
    internet2.voicestream works for me but i can't send any pictures that's why i had to add a second APN. When i Add a second APN for MMS, everything works great except when i turn on my GPS, the apn changes from my default which is internet2.voicestream to epc.tmobile.com which is my MMS APN. I also loose Data Connection.
    Are you on the T-Zone Plan?
    Sorry to bother you but if you could please help me out, I will really appreciate it.
    Thanks:nexusx:
    Nope. What is there was there by default. There is only the * there. If I enter a letter or number, it doesn't change to *, so I assume that is the real entry. I even did several factory resets, and that is what always shows. I'm on a post paid family plan. Maybe it's not compatible with T-Zone? Sorry I can't help more.
    that's probably why i did't work because you have a regular data plan.
    Thank you for trying to help.
    If there's anybody that's experiencing the same issues, I will really appreciated it if you can help me out
    Thank you in advance.:nexusx:
    You need to create TWO set of APN
    1. For data
    Name: whatever you want to call it (I use Tmobile US)
    APN: internet2.voicestream.com
    MCC: 310
    MNC: 260
    Everthing else is either blank or not set.
    2. For MMS
    Name: whatever you want to call it (I use MMS)
    MCC: 310
    MNC: 260
    APN type: mms
    Everything else is either blank or not set
    I have the Web2Go plan ($9.99/month).
    Ne:nexusx:uS One ROOTED
    Cyanogen Mod Nightly ROM
    Member wannagotopopeyes's Avatar
    I have the OLD 5.99 T-Zones plan and use just the bottom APN of this post with epc.tmobile.com. I get full 3G and MMS all the time w/o any trouble. Try setting your APN settings to default then rebooting then using only the bottom APN.
    1. For data
    MCC: 310
    MNC: 260
    2. For MMS
    MCC: 310
    MNC: 260
    APN type: mms
