Need Help Rooting ZTE Score!
This is a discussion on Need Help Rooting ZTE Score! within the ZTE Android Phones forums, part of the Android Phones by Model category; Does anyone know how to root the ZTE score running 2.3.4 gingerbread???? Pleases let me know!...
Thread: Need Help Rooting ZTE Score!
    Android Lurker unclebrandon1's Avatar
    Jun 2012
    Android Lurker porter1982's Avatar
    Oct 2012
    There is a thread if you have a n762 use the clockworkmod and voltron Rom pm and will walk you through it
    Sent from my N762 using Android.net
    Oct 2012
    Here is the link, download all three and install clockwork on sd card and update by going to settings about phone and update from sd it should start and run, when done ur phone will reboot. Turn it off go into recovery by pressing power,vol up, and the first button on the bottom left at the same time. Once clockwork recovery shows up go to install zip from sd and choose.....choose zip from sd when u see the voltron zip file press home button and scroll down and press home and it should install
    Oct 2012
    http://androidforums.com/other-phone...orage-use.html
  1. ZTE Score Rom Dump???
    By nobreak1970 in forum Rescue Squad Help
    Last Post: 12-26-2011, 03:02 PM
  2. Sports score widget
    By Jonnypecs in forum LG Ally Apps
    Last Post: 11-29-2010, 06:26 AM
android zte help
blackice rom zte score download
download free rom for gingerbread zte score
downloads for rooting zte score
how to root zte score android 2.3.4
is the zte score gingerbread
is the zte score runing on gingerbread
need help rooting zte
rooting zte score
verizon zte root
what is rooting a zte score
zte score fast root
zte score gingerbread rooting
zte score help
